Springs in the old days used to outlast shocks by a large margin. Shocks generally degrade in performance over time before they finally and usually suddenly fail. Often they visibly leak fluid long before final failure.
Not easy to answer your question but if the shocks are OK, not showing signs of leakage and you are happy with the ride and handling then I would (and did) replace the springs only. However if you are a sporty driver in your Croma wanting to have the best handling you can then I would change both at the same time. I'm a sporty driver always when I'm out in our Barchetta or Strada Abarth but with the Croma only sometimes. The Croma is not extactly a sporty car that you can get long term pleasure from throwing it around and pushing the handling. It is fun for a while but after that gets boring and tiresome.
