Hi has anybody managed to connect to their Power steering system using Fiatecuscan 2.5 and a modified cable.
Paul D
Paul D
Update.
I have now managed to connect to my power steering ECU with my ELM cable. The reason for the original problem was..... When you modify a cable make sure you realise the obd pinout refers to the one mounted on the car (Male connection) and you connect to pin 12 and not pin 13 on you ELM cable (Female connection).
PaulD
Update.
I have now managed to connect to my power steering ECU with my ELM cable. The reason for the original problem was..... When you modify a cable make sure you realise the obd pinout refers to the one mounted on the car (Female connection) and you connect to pin 12 and not pin 13 on you ELM cable (Male connection).
PaulD
