General Climate control fan problem
u21066powers
:eek:Climate control fan on my croma is on full all the time. Cannot slow it down using +/- buttons. Only way to stop it is to remove climate control fan fuse.
Any ideas
george
Sounds like the speed controller module has failed short circuit OR a wiring fault, e.g. damage/chafed wired
Looking at the parts list I can't see a separate speed control, just an overall panel control unit. This costs around £250 ...ouch
eLearn suggests that there is a separate "resistive divider" but on the Automatic Climate Control the motor speed is directly controlled from the "climate control node"
Have you seen the ebay auction here ? If you need any other bits they might have them too.
Thanks everyone. Diagnostics at garage said its an internal short in the fan motor £250 fitted
