FIAT Auto Specialist Team
Thread Tools
Old 19-06-2010   #1
Italy
Problem with Differential Pressure Sensor
Hi! Is this the right section where write about a problem? (sorry I'm new...)
I've a problem with my Croma '06 1.9 Mtj 16v 150cv
Error Light is on (yellow engine light) but car goes good (no recovery status)...only error-light on
I connected my pc to the ecu via OBDII and fiatecuscan software
error is: P2453 Differential pressure sensor error
I deleted the error but when I acelerate over 3000 rpm... it comes back
So I decided to control the differential pressure sensor, and...there's a surprise: as shown in fiat e-learn software for croma, this sensor has to be with two air-tubes inlets for two pipes from DPF...but mine has only one inlet!
sensor e-per code I think could be: 55200301
to explain better:
do you see "2C"? the sensor on my car has got only one of these pipes and no possibilities of any othere entrance...the sensor has only one inlet...
do you know about any other differential pressure sensor that could be in an other place?
what do you think I've to do?
(no dpf regeneration because the error of the sensor appears the regeneration procedure stops)
p.s. sorry for my english...
albyhf is offline Reply With Quote Quote
Old 19-06-2010   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Problem with Differential Pressure Sensor
thats not diff pressure sensor, looks like overboost sensor
Old 19-06-2010   #3
Italy
Quote Originally Posted by T14086 View Post
no it's not
overboost sensor? maybe you mean APS (absolute pressure sensor) I think: and the sensor on my car appears like that...yes...but....
Looking the image I posted: that's the differential pressure sensor, as i said: the image is from an official e-learn cd
if you don't believe me, the follow one is the image from e-per:
as you can see it's the same sensor
the one on my car is identical, in the same position, but with only one inlet for a pipe that goes under the car.
I think I'll ve to go under my croma to see how is the situation with it and the dpf
I've the suspect that in the past someone changed the original sensor not to have problems with dpf....so it takes pressure not differential but absolute....but it's only an idea...
In any case I checked the error code and it seems poor pressure at high rpm....I explain: when you acelerate, the dpf resists to the air and so you have a higher pressure..and the differential sensor detect it...the problem with my car is that the sensor doesn't detect this higher pressure..the ecu detect this incongruity and so the error light turn on...
so I can have different problems...for example a hole somewhere...or the sensor broken... the mistery is the sensor with one inlet only
P.S. sorry an other time for my very bad english....
Old 19-06-2010   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by albyhf View Post
Thanks but I know where the diff pressure sensor is, changed loads of them but i'm still not sure what you are asking in your opening post?
Old 19-06-2010   #5
Italy
if you know where the sensor is I don't understand you
it's for my bad english?
Old 19-06-2010   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
yes i'm getting confused here.
there are 2 types of set up, one has 2 pipes and a later system has 1 pipe to measure DPF pressure.
2b is the sensor as your picture shows, if this error is there all the time check the 1 or 2 pipes that go to the DPF filter. If these are ok and sensor ok then you need to check the filter clogging and oil degredation on Fiat examiner diagnostic equipment.
Old 19-06-2010   #7
Italy
ok thanks!
so exists also a 1 pipe sensor...so that's the one I've got...
filter clogging for examiner is 30% and is classified "normal clogging", oil degradation is 60%
I can't make dpf regeneration because the procedure stops for the differential pressure error.
I mean: I delete error, trying regeneration: when the engine goes to 3500rpm the error light turn on and the procedure stops.
So as you suggest I will check the pipe from the sensor to the DPF...but if it's ok do you know the code for the one pipe sensor?
thank you!
Old 19-06-2010   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
do you have examiner or laptop computer with examiner software?
Old 23-06-2010   #9
Italy
as I wrote, I've fiatecuscan
anyway: all solved, the problem was the sensor (that now is with only a pipe)
thank you!
Old 23-06-2010   #10
Forum Moderator
T14086's Avatar
T14086 has donated!
Has the car carried out a regeneration (not forced) since?
Old 25-06-2010   #11
Italy
Odometer at last regeneration: 79,2 Km
Particle filter obstruction: 20,36%
Particle filter status: not clogged
Old 26-06-2010   #12
Forum Moderator
T14086's Avatar
T14086 has donated!
Old 24-12-2010   #13
the notorious one
notorious's Avatar
notorious has donated!
Serbia
Fixed mine today. The bigger rubber hose had fallen apart on the topside (hard to see) in the area just before the dpf. Sensor turned out to still be good, but got battered in the diagnostics process so was replaced with a used one from a 2007 Croma. No more fault popping up at highway speeds.
Serbia is not suburbia.
notorious is offline Reply With Quote Quote
Thread Tools
(G) pressure sensor klairabell Ulysse 1 15-11-2006 16:03
(G) pressure sensor klairabell Ulysse 0 17-07-2006 15:04
(T) Problem with differential stefanmr Marea 7 03-05-2006 13:47
(T) Pressure sensor??? T140 Punto (Mk2/2b) 7 12-07-2004 04:07
