I've recently changed mine to a K&N with no problems at all, have driven 2000 miles since (EDIT: Mine's just a filter element in the OEM box, don't know about yours).
Back on topic, I bought mine at 2.5 years old so still had some warranty. I had the sunroof mechanism and motor replaced (which is a huge job - I think they took the windscreen and headlining out to do it), and it's still stiff and sometimes needs a helping hand to close. I've decided not to worry about it - as long as it doesn't leak (and it doesn't) then I'm very happy to have the glass area alone.
The blind motor seems to be very related to the sunroof motor. When I managed to confuse/jam the sunroof the blind also failed.
The manual says the hand-cranking lever is in the glovebox. Mine was clipped inside the rear interior light (where you need to plug it in). If it's missing then an allen key should do it, if there's enough clearance and you can get enough leverage.
