hi need help from you, before i go to the stealers
basically it started about 2 weeks ago, after a cold start, when tried to apply brakes there was non!
when pumped up the car would stop eventually
brake pedal feels spongy, there is no biting point, with the engine on if i apply constant pressure the pedal will go right to the floor
with the engine off i can pump it a few times and it will become and stay solid
went to kwik-fit this morning and the told me it's the master cylinder broken, but after gooogling i've found on volvo's forum very similar problem being solved by vacuum pump replacement
any ideas before i go and part with my cash?
just to add: the problem seems intermittent
