stuart543
Hi, I’m new here. What a great forum this – I discovered it yesterday and have found many useful tips. I run a 55 reg Croma 1.9D 150hp Prestigio auto which I purchased in April 07.
I’ve been very happy with it until just before Christmas when I collected it from the local fiat dealer following a routine service. As I drove away I noticed the battery light was on and then various functions (climate control, ABS, ESP, window safety cut off etc..) began to fail one by one. When I got home I stopped and re-started the car and noticed that it was idling at 1100rpm instead of the usual 800 then the power steering went and following that the car failed to re-start. The car was recovered by the dealer who diagnosed the problem as alternator failure. I was then charged £205 +VAT for a reconditioned alternator which they fitted for free (as it had been fine before they got their hands on it). The car now works, but
(1) The battery light still stays on even though tests have shown that everything is working as it should be. However, bizarrely, it goes out if you turn on the ignition, then turn it off, then start the engine. The only solution the dealer can offer me is a new computer (I think they’re just guessing!!!)
(2) It takes several seconds to fire up on cold start (pre-service it was almost instant) and sometimes needs two attempts and then runs very roughly (sounds like a tractor) for 30 seconds or so. Fuel consumption has fallen by some 20% from previous levels.
Any thoughts very welcome. Thanks
