Old 04-01-2010   #1
EOBD plug position
Hi All
Can anyone please tell me where the plug is for the EOBD / OBD is location on my 2006 Croma?
Dave
moynesyt5 is offline Reply With Quote Quote
Old 04-01-2010   #2
Re: EOBD plug position
It's behind the cubby hole on the dashboard where your right knee is. You have to remove a philips screw to get the cover off.
HTH.
DoIDon'tI is offline Reply With Quote Quote
Old 04-01-2010   #3
Thanks for that. I did look there, but obviously not hard enough!
Dave
Old 04-01-2010   #4
s130 has donated!
Up to top RHS of fuse box. Partly hidden by the two large cables.
s130 is offline Reply With Quote Quote
Old 05-01-2010   #5
The two thick cables 'hid' the plug when I first looked!
Old 05-01-2010   #6
s130 has donated!
Pleased you found them.
Can I ask what device / software you are planning to plug into/use on the Croma?
Old 06-01-2010   #7
I've bought a U581 reader, so hopefully this will work. All the reaqders / scanners say they work on Fiats etc, so I'll give it a try.
I'll let you know how I get on.
Old 19-08-2019   #8
Is there an EOBD/OBE port on a Croma CHT/IE ?
icom102 is offline Reply With Quote Quote
Old 20-08-2019   #9
s130 has donated!
Quote Originally Posted by icom102 View Post
This is the old original version of the Croma 1992 and in does not have an EOBD socket.
Connections to the Engine ECU and ABS system, etc. are via Fiat 3-Pin connector interface.
MultiECUScan support the Croma 92 but only the Engine and ABS ECUs. You will also need the 3-Pin adapter cable.
Thanks g8rpi thanked for this post
Old 20-08-2019   #10
Old 20-08-2019   #11
Moderator
g8rpi's Avatar
g8rpi has donated!
Note that you need the KL / VAG-Comm to USB interface (and 3 pin adaptor) for the 92 Croma. The newer ELM-327 interfaces won't work.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
(T) Gearbox oil change; drain plug & fill plug? combwork Multipla 3 03-07-2009 09:50
(T) Broken Spark Plug Cable + EOBD Light On Brava2001 Bravo / Brava 11 28-12-2008 10:32
(G) have you seen a thing you plug in to cig lighter and has plug on other end fletcher11 Punto (Mk2/2b) 3 20-02-2008 12:16
(T) Eobd Lenny81 Punto (Mk2/2b) 2 14-12-2007 05:04
Butt-Plug? Ah! Spark-Plug? (worksafe) MrDerv Leisure Lounge 6 05-07-2004 03:40
