Update on fuel consumption after remap;;; around town and short journeys 45.1 mpg. Long distance 70 to 80mph 51.4 mpg In both cases an improvement of 6 mpg. Hope this helps.
CJLAR
CJLAR
Is this calculated from the pump input, rather than the on board computer averages?Update on fuel consumption after remap;;; around town and short journeys 45.1 mpg. Long distance 70 to 80mph 51.4 mpg In both cases an improvement of 6 mpg. Hope this helps.
CJLAR
When I accelerate hard it still seem to clutch slip some but it only seems to last maybe 1 or 2 seconds and then stops. As in when I floor it the tach will jump up maybe 200 rpms for a second or two and then drop back down. So the question is...is it really clutch slip or is it a ECU thing?
With a manual gearbox car, revs rising without a corresponding increase in road speed = clutch slip. The ECU (or anything else for that matter) can't do this, it's a straight mechanical drive.
HTH.
The questioning I have is could the computer sense the clutch slip situation and reduce power output?
BTW...guess no one knows anything about wipers?
How much more would a clutch with a little more clamping pressure cost the manufacture? Especially if it would allow Fiat to tune the motor up (for free, cause its a progrmaing change) and claim more power and better fuel economy?
