Feeling bored, want something to do this evening or tomorrow?
I would be pleased if you can try this little test when you have a moment.
With the engine running at idle rpm and whilst parked up, pump the break pedal a couple/few times till really firm and then keep hard pressure continuously on the brake pedal over several minutes.
Does the pedal creep to the floor ? Mine does.
Usual break / MOT tests are all ok i.e.
a) Engine off, pump pedal to release vacuum and hold. No creep detected.
b) Keeping pedal depressed, start engine. Pedal should depress as vacuum/servo cuts in.
c) Release pedal and turn engine off and wait 15 to 30 seconds
d) Pump break pedal (engine off as per (c) ) and a hiss (vacuum release) should be heard as the pedal depresses. Even pump cylces after that the hiss should get less, the pedal depress less and finally go firm after 3 or 4 pedal strokes.
My Croma passes all the (a) to (b) tests above but with the ignition on and engine running idle creep test the pedal will eventually creep to the floor.
I've not yet tried suitable test with just the ignition on.
Now the Croma has "hill hold" and my sloping drive often causes this to come into action and when it does I've noticed huge changes in break pedal feel/response.
I'm beginning to think that this creep is a function of the ABS/Break unit/system and not an issue but I am interested into what other people find becuase if there is an issue I want it sorted before my 3 year warranty is up.
