Any suggestions as to the cause of mystery noise affecting my wife's 1.9D 16 v automatic? Occasionally, as she accelerates or sometimes decelerates, you hear for one or two seconds a noise which is difficult to describe, but imagine if you will two plastic discs, one stationary the other rotating. They should not touch, but for some reason contact is made for one or two seconds making a whirring noise. This in no way affects the performance of the vehicle which is 3 y.o. on an 06 plate and has less than 12000 on the clock. The local dealer where the vehicle was purchased and has been regularly serviced, at first denied hearing the noise on a road test. When I insisted on going out with a senior technician at the wheel, we both heard it and he said that it was almost certainly a turbo fault. The subsequent visit by a Fiat engineer to check his findings resulted in a denial of faulty parts but was described as "an induction noise", whatever that is. Appealing to Fiat via email has resulted in a polite brush off. I am left with a Croma that performs perfectly but that I assume any future prospective purchaser would turn down flat on hearing the intermittent noise, or that the dealer would offer bottom dollar for on a p/ex deal, knowing of it's history. Suggestions?
