Not sure DPF = lower CO is correct. To my knowledge the Croma DPF is a non catalyser DPF and therefore only traps soot to be later burnt.
Interestingly (
http://www.euractiv.com/en/transport/euro-5-emissions-standards-cars/article-133325) Euro 5, Jan 2009 makes DPF filter compulsory, but prior to that they were not.
Fiat were early adopters of DPF with their vehicles, including the Croma, so I'm pretty sure it will be possible to pass existing diesel MOT levels with NO DPF fitted. This means that one could possibly remove the DPF completely and replace with a standard middle box or a straight through pipe.
I see loads of 2005 diesel cars, Audi, VW, Merc etc. spewing soot under load but never a 2005 Croma, Multipla or Panda.
Now unless the MOT limits specifically target and set levels for individual cars, which they have never done in the past and would be very difficult and complex to do, then the levels with be as per Euro 4 or Euro 5 BASED on year of applicability. Croma is Euro 4 era but should easily pass Euro 5.
Any MOT testers out there care to comment?
ECU / engine should not be affected by no DPF and there will be no pressure differential created and thus no regeneration cycles requested (based on pressure). Oil change interval which is partly based on number of regen cyles will at worst just default to 18K miles.
Nick /////
