Old 08-09-2007   #1
Shaking Croma
Having a problem with the Croma. Under acceleration the car shakes noticably. At certain sppeds there is also a vibration but it becomes extremely obvious when you put your foot down. I have had it in the dealers yeaterday and they have checked for any ecu problems and played around with the ECU. But it's still happening.
Any suggestions?
Croma Prestigio 1.9 150bhp auto
Alan C is offline Reply With Quote Quote
Old 08-09-2007   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Shaking Croma
Make sure its had the ECU software update (swirl actuator)
Old 09-09-2007   #3
Re: Shaking Croma
The garage did the ecu update on it but it hasn't made a difference. Is there any history of suspension or bearing problems which may cause it or could the wheel tracking/balancing cause it? I'm not an expert as you can probably tell!! It seems odd that it at some speeds it is more noticable than at others, and it is bad under heavy acceleration.
Old 09-09-2007   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Shaking Croma
There is a recall on rear tyre wear checks...Alan i'm not exactly sure if your describing a mechanical vibration/fault or a engine running fault...can you elaborate abit.
Old 09-09-2007   #5
Re: Shaking Croma
It's hard to tell whether it's from the engine or elsewhere. It just seems to get worse when i put my foot down, which led me to thinking that it was to do with the engine. The car has always had a slight vibration when driving it. Recently it has much worse. I even had to stop on the way back from London to check if there was anything wrong with the tyres, as it turned from a vibration to more of a shaking or thumping effect. I have noticed a metallic rubbing sound which seems to be coming from the n/s rear. This noise was more noticible before i changed the tyres, but is still there now. Is there any way i could check for this rear problem before i put it back into the dealers?
Old 09-09-2007   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Shaking Croma
OK...theres a recall for 'shudder' (not same as swirl chamber update.
I would also get wheel geometry set...dealer to do this as there is a particular way to do this.
Check for outstanding campaigns in particular 5138...dealer can check this for you.
Let us know how you get on?
Old 10-09-2007   #7
Re: Shaking Croma
Hi there
At easter coming home our Croma 150 developed a steady vibration as we were going down the M4 loaded down with the family holiday kit. Not so much under acceleration just at a constant speed down the moterway. However,changing the rear tyres seemed to solve this as these were at the end of their life (at just over 15000 miles, which doesn't seem great)- it was only after this we found out about the tyre wear recall.
We haven't experienced this effect again, even when similarly laden down in France last month. However, the instrument cluster did fail on the penultultimate day- error messages in any language but English for any and all possible problems, no speedometer, then no rev counter. This continued once we got home after it initially being diagnosed as just a lose connector and we've just had a new instrument cluster fitted which has solved this problem.
Thankfully our local dealer Motor Services of Chepstow has been great about sorting this out with Fiat and they've only dealt with one other Croma!
We've had quite a few little problems with the Croma (any one else's front seat belt buckle plastics cracking up?), but we do like it and it was great on holiday (and we weren't alone- there were Dutch and French ones on the same campsite!).
patcp is offline Reply With Quote Quote
Old 12-09-2007   #8
Re: Shaking Croma
Thanks. Have got the Croma booked in on Monday. Are there many recalls on the croma at the moment?
Old 12-09-2007   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Shaking Croma
Quote Originally Posted by Alan C View Post
about 8 or 9 from memory but most were done before car was put on road & not all apply to any one version/factory/build date etc. Dont be put off by this amount as most are silly thing like putting grease on fuel filler cap!
Old 22-09-2007   #10
Re: Shaking Croma
Hi all.
should the dealer have notified me of the rear tracking issue. I got through 2 sets!! of rear tyres in the first 18K miles (15months), decided to get the rear tracking checked and it was way out. It was realigned at a local tyre dealers, fitted with a 3rd pair 13K miles ago, less noise, more mpg and better handling. I shall be contacting FIAT for compo if the fault was known and and not notified.
watto is offline Reply With Quote Quote
Old 22-09-2007   #11
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Shaking Croma
Quote Originally Posted by watto View Post
Hi all.
what rear track issue?
Old 02-10-2007   #12
Re: Shaking Croma
Heard from the dealers today. They say they think it is a rear bearing problem and are going to replace these. Fingers crossed i might get the car back this week. Getting fed up of the grande punto courtesy car!!
Old 02-10-2007   #13
SNAP!
luvduvs's Avatar
luvduvs has donated!
Australia
Re: Shaking Croma
What don't you like about the GP?
luvduvs is offline Reply With Quote Quote
Old 02-10-2007   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Shaking Croma
Quote Originally Posted by luvduvs View Post
croma is a far superior car.
Old 03-10-2007   #15
Re: Shaking Croma
It's just too small. Wife + 2 kids to transport around. No toys on this one and it doesn't want to go fast!!
Am I Insane ...thinking of buying a Croma!! Angryeyes Lets Talk FIAT 77 08-07-2008 21:01
croma section The Sultan Site Ideas 11 30-07-2007 18:14
News - Fiat Croma Is Awarded The Euro Ncap 5-star Rating Steven Lets Talk FIAT 21 03-03-2007 23:08
insane shaking!! nader127 Lets Talk FIAT 16 30-06-2006 12:22
Fiat Croma Pointlessness Dr_Pepper Leisure Lounge 3 08-02-2005 07:53
