Comment
Guide Tools
<!-- google_ad_section_start -->DENSO ALTERNATOR RECTIFIER REPAIR<!-- google_ad_section_end -->
Published by dave
06-11-2012
Difficulty Level: 3
User Rated:
Difficulty Level: 3
I got my new part from ebay seller stenetbrown http://myworld.ebay.co.uk/stenetbrow...:X:RTQ:GB:1181
Friendly seller and very helpful, even provides a bit of solder.
remove ALTERNATOR from car, (see other guide)
Remove plastic black end by pulling tags slightly outwards.
Remove 3x8mm nuts, 3x washers, 2x plastic insulators.
Remove 13mm nut, washer and spacer. then 2 cross head screws, note the 2 screws are not the same size.
Carefully lift of the regulator
unsolder the 3 crimp joints and un fold them, my soldering iron didn't seem to want to melt the solder so i carefully used mini blow torch.
Lift of the rectifier and replace with the new one, crimp the crimps and re-solder, i used mini blow torch again.
Remove the middle cap of regulator covering the brushes there is a tiny tab that needs pushing in, this makes it so you can hold brushes in when refitting it,
hold brushes in and refit. replace brush cap.
Replace all the insulators. washers, nuts screws and the plastic end cover.
clean kitchen up before mrs gets home if you have one, if not relax with favorite beverage
Thanks wot4y, Astorga, Roberto Blanco thanked for this post
Old 18-05-2013   #1
Mexico
Re: DENSO ALTERNATOR RECTIFIER REPAIR
DO YOU O ANYONE KNOWS WHERE CAN I FIND THE REGULATOR?
THANKS
Astorga is offline Reply With Quote Quote
Old 18-05-2013   #2
Trader Rating: 10
dave has donated!
Old 18-05-2013   #3
Mexico
Thanks for the reply, what this guy is selling only the rectifier, but I need the rectifier and the regulator (black one), both parts.
Am I wrong and this guy sell both?
Old 18-05-2013   #4
Trader Rating: 10
dave has donated!
i would think he can get it from his suplier, send him a message and ask him
Old 18-05-2013   #5
Mexico
Thanks Dave
Old 13-06-2013   #6
Mexico
I have found someone who has the regulator and the rectifier in case that you need both is a great seller on ebay
http://www.ebay.com/itm/181050138325...84.m1439.l2649
http://myworld.ebay.com/m.u.r.e?_trksid=p2047675.l2559
hope it would be useful
Comment
Guide Tools
(T) alternator repair dave Croma 50 11-11-2012 07:38
(T) Denso Parts on Panda Irish Cento Panda 1 26-02-2011 02:36
(T) Alternator Failure after another repair? jadento Croma 12 18-11-2010 11:58
denso iridium plugs custard Auction Watch 0 09-08-2006 13:27
(T) Splitfire vs denso iridium Dan Cinquecento / Seicento 7 09-12-2004 00:18
