soozukisteve
Hi guys,many thanks to all of you that posted on my cinq/uno turbo project thread.no updates so far as ive been so busy.
One of the things keeping me so busy was slotting the punto 75 engine into my daily runaround cinq sx(with full sporting kit-engine,susp,int etc...)
I used the 1108 head on the punto block with the 75 cam.I tried to use the 75 throttle body(ported to match the spi injector top section) but it suffered from a massive hesitation and the idle speed was so low it kept cutting out.
I was quite impressed when i took it down the road but the hesitation and stalling spoilt it,so i swapped back to the cinq throttle body!
Just been down the road and cant wipe the smile off my face.its wicked!!one problem though.it doesnt seem to want to rev out.it gets to approx 5000rpm and it feels like a soft rev limiter is cutting in.If you hold,it will gradually pull to approx 6000 but feels a bit like its missfiring but not as pronounced as that.
It was the same when i had the 75 throttle body on so initially put it down to that!
I did wonder about the fuel supply but i read that the standard spi should cope with the requirements of the 75 engine quite easily.
All the sensors and electrics have been swapped over from the 1108 (as that was running perfectly (and revved all the way into the red!!!)) to eliminate them,but no luck.
does anyone have any ideas??
steve
steve
