Thread Tools
Old 13-03-2007   #1
Bring On The Trumpets!
ronnieronson's Avatar
ronnieronson has donated!
Question Dashboard / instrument leds
I know I risk repeating a topic that has been covered many times on here but here goes...
Having read every single post I can find about interior bulbs, scoured my haynes manual, and trawled ebay, I cant seem to find out what the type of bulbs are called required to change :-
*Clock illumination bulb
*heater controls bulbs
*dash instrument panel bulbs
Also I'm not sure hoe many I need - afaik its 4 bulbs for the instrument panel (or is it just 3?), two for the heater controls and one for the clock.
Basically I'm after converting them all to blue LED - if anyone knows what fitments I need or cant recommend an ebayer / retailer to buy them from (I have already tried crazyleds)...
Edit: possibly found something - a 509t bulb? anyone used these?
ronnieronson is offline Reply With Quote Quote
Old 14-03-2007   #2
Re: Dashboard / instrument leds
....Ok, so I've taken my dash apart - seems like the twist lock 509t LED's will fit for the clock, and dash gauges - but I cant figure out what bulbs I need for the heater controls - would it be a 286?
looks like this:-
Old 14-03-2007   #3
yo mate
yeh this is a repeated subject but i'd like to add my 2 cents and say dont bother with little naf LED's for the heater controls and make your own circuit board for some! really! because the socket goes at one end, the other end gets little light and the green on the dial doesnt let much through apart from green!
curcuit board, i did!
i did one and then got side tracked and endud up losing the other LEDs for the bottom one so i wil bashing it out again next trip to Maplin
if you want me to make you some for minimal price, let me know
u can see pics on my website page
but if you do want some unfulfilling ones then they are these:
http://www.ultraleds.co.uk/default.p...fca47c108f9148
286
this site is the best for LEDs mate
AxelEph
Bits for sale:Passenger Mirror in Yellow, Yellow Samco Hose
AxelEph is offline Reply With Quote Quote
Old 14-03-2007   #4
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Old 14-03-2007   #5
arc
this is where i stand
arc has donated!
are you planning to replace all the dash warning lights with LEDs too? If you do, do not replace the battery warning or ECU lights. The car really doesnt like that, led to me buying a new alternator that i didnt need and getting very peeved off with the car!
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 14-03-2007   #6
custard's Avatar
Trader Rating: 1
Quote Originally Posted by arc View Post
im sure they read that warning in guides section
Old 14-03-2007   #7
Question Re: Dashboard / instrument leds
Quote Originally Posted by custard View Post
lol yeah I'd already picked up on that one - but thanks for the reminder.
I'm pretty sure I don't have light for the ecu (my cinq is an 899), but in either case I only have intentions to do the heater lights, clock, speedo, fuel and oil temp.
Now then - here's part two, managed to source some leds which should arrive tomorrow or friday.
It's pretty obvious how to fit twist lock style bulbs, but I'm a tad foxed about fitting the bulbs for the heater guages.
I didn't really try too hard yet to remove the existing bulbs, but do they just pull out or is there a knack to getting them out?
Thanks for your help so far guys - some useful info come out of this thread for me
Old 15-03-2007   #8
heater control lights just pull out.
not easy mind and i remember using some pliers when i had a punto and broke one of the bulbs in its hiolder....not fun!
so just be carefull and wiggle is the best way
PS the leccy window buttons are also the same as heater controls
Old 15-03-2007   #9
also
you haven't mentioned anythin yet about your button LEDs
does that mean you know all about them and the fact u need to solder the one behind your headlight/sidelight button?
if you don't know about these, then they are simple. take the switch apart and but in a 3v...i think...LED. i bought mine from maplin and they juut push in. but be sure you put them in the right way! alse they wil blow. the buttons already have resistors so best check the colour code of them and find out the voltage drop before buying the LEDs.
Note: the headlight/sidelight switch doesnt have a resistor.
PS. while your dash is in pieces can you do me a favor and take a good picture of the circuit board behind the dials. am thinking seriously about ripping it out and customising it by puting in LEDs in the actual places cos the placement at the moment is annoying as it doesnt distribute properly.
PM would be awesome
thanks mate and good luck
AxelEph
Old 15-03-2007   #10
custard's Avatar
Trader Rating: 1
how about we keep it on the forum for the benifit of all?
Old 16-03-2007   #11
Talking Re: Dashboard / instrument leds
Thanks for all your help guys - just finished putting the bulbs in, and from what I can tell things look peachy
Too early to tell the full effect but if I can think on I shall post some photos tonight when it's gone dark.
Old 16-03-2007   #12
Just had a little thought (mainly because the sticky doesn't explain things 100%) - how exactly do I go about removing the green glass from behind my dials?
I'm very nervous about totally screwing up my mileometer etc, so any advice on this would be a godsend...
Edit: ...Ooh, also meant to ask - there is a larger bulb behind my clocks, which is a twist fit - can't seem to find out what the size is on that one, or whether a blue led replacement is available... Any thoughts?
Old 16-03-2007   #13
custard's Avatar
Trader Rating: 1
is that not the battery light?
Old 16-03-2007   #14
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
Quote Originally Posted by ronnieronson View Post
On the mondeo there is a twist fit type bulb for the headlight switch, that is size 501 and it is available to have a blue LED, there is an ebay power seller that does them.
Maybe could be it reg. size?
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
Old 16-03-2007   #15
Unhappy Re: Dashboard / instrument leds
Erm.... the battary light seems to be at the bottom of the gauge assembly (899cc dash), but tbh I'm not 100% what that bulb is for.... I can only assume it's the main bulb for the speedo, purely because of where it is positioned.
As you look at the guages (with them installed) the bulb is positioned toward the top left of the speedo...
It's hard to tell whether it comes on with the other bulbs at the mo because it's still really bright outside
Thread Tools
(S) Dashboard LEDs YELLOWNITR8 Cinquecento / Seicento 25 16-07-2007 00:45
(T) instrument panel / dashboard ovidiuaproporo Uno 0 08-01-2007 20:25
(T) flashing leds after replacing dashboard roadrunneruk Punto (Mk2/2b) 10 23-03-2006 00:20
(T) How To Remove Mk 1 Dashboard Chas Uno Uno 3 03-08-2005 01:07
