Right-
Cinq Sporting 1.1 - Just taken out an engine (old Van Aaken High Boost Turbo conversion) an replaced it with another one (standard, albeit with a 6 speed box). Everything is now back in and connected (I think!) but the engine turns and won't start. The fuel injection light in the dash comes on when the ignition is on and then starts flashing. It flashes 33 times (of any importantce??) and then stays on. There is no fuel being pumped in through the injector and as a result no sparks. When the ignition is turned on you can't hear the fuel pump startup. Have cheaked the fuel cutoff switch and don't think it's that or the crank sensor+HT leads in right places.
I'm now kinda stuck!!
Any ideas or help greatly apprieciated-wires that may not be connected/blocked stuf????? - anything.
Cheers,
Matt
[xx(][V][xx(][V][xx(][V][xx(][V][xx(][V][xx(][V][xx(][V]
"No it's not a custard"
Cheers,
Matt
