M matt_cinq New member Joined Jan 19, 2007 Messages 5 Points 3 Feb 9, 2007 #1 Hi all i have fitted a ecu with a mckrich chip fitted so the keycode light stays on i hear that u can unplug the transponder for it but where is it found???? thanx for any help matt c
allanhelen I Need Beer Parked in the garage Written a guide Joined Mar 21, 2006 Messages 3,162 Points 589 Location Looking at an empty Glass Feb 9, 2007 #2 Did you get the instructions with it from Mike I am sure it tells you what to do in there. But do a search I'm sure I have seen disconnecting the Code box in a few posts
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh Feb 9, 2007 #3 its under the steering coumn. its has 2 plugs,one turns the light out. its the code box,the transponders in the key
OP OP M matt_cinq New member Joined Jan 19, 2007 Messages 5 Points 3 Feb 9, 2007 #4 ok thanks for the help ill have a nose
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh Feb 9, 2007 #5 should have been more clear.its right up behind the fusebox. black a bit bigger than a pack of fags
