Old 03-02-2007   #1
Sweden
How long a bump stop...
you reckon should be in the front for -40 springs. Today I realised my suspension is practically sitting on the bump, I have cut it by 1cm, seems to be better. But in absolute values - how long/high? And please do not tell me in terms of "balls", cause I have new fiat stop bumps that come in one piece with the shock protective rubber, and there are no real "balls" to talk about (rather rings I would say...).
Cheers,
Woj
woj is offline Reply With Quote Quote
Old 03-02-2007   #2
arc
this is where i stand
arc has donated!
Re: How long a bump stop...
i just cut them in half
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 03-02-2007   #3
lowerd it by 40mm, i'd take it off by about 20mm.
[FONT="Comic Sans MS"][COLOR="DarkRed"]2003 Landrover Freelander S 2.0L Td4 :D [/COLOR][COLOR="Blue"]1989 Toyota Celica GT4 St165 Engine rebuild underway:rolleyes: [/COLOR] [COLOR="Red"]Fiatless once again :cry:[/COLOR] [/FONT]
Rampage94 is offline Reply With Quote Quote
Old 03-02-2007   #4
kritip's Avatar
Trader Rating: 4
kritip has donated!
Do you have the normal shocks, or uprated?
I found the fronts to be fine, the rears however, needed a good cutting
Kristian
kritip is offline Reply With Quote Quote
Old 04-02-2007   #5
Sweden
Shocks are bilstein b4. I used to have (quite worn out) -25 springs mounted by the previous owner. The bumps on the front I guess were untouched, in the back they were obviously cut, so no probs with the back, even with the -40s. But in the front with the -40 springs they defo need to be shorter. So far I have cut off about 1 cm and it seems to work (at least now I can see that the suspension works and is not just stiff like rock), but I guess then another 1cm is in order. I will ask differently - how much height should give the shock to work?
Cheers,
Woj
(T) Front Wipers Don't Stop Properly. GavN Cinquecento / Seicento 13 24-01-2009 15:09
(T) Does my Bum(p stop) look big in this (Cinq?) Liam Cinquecento / Seicento 21 14-09-2005 16:44
(T) Engine stops, when I stop! DJM2005 Punto (Mk2/2b) 1 15-06-2005 23:17
(G) Stop Leak products gholian Uno 0 04-01-2005 16:21
(G) how long will you keep your car andi Cinquecento / Seicento 31 25-11-2003 21:40
