Sporty_5_Seicento
Member
Hi
Recently purchased a flywheel (think it was a member on here that used to own a certian imola blue turbo cinq ) for my sei 2000 SPI. Im sure it fits as someone has said on here.
My dad is gonna lighten it. Ive read the posts and know how to lighten and what parts to remove from and how much to take off thats not the problem.
Ok heres the problem. He phoned up a motorbike engine tuner who owes him a favor for him doing some work on a caravan LMAO (this guy tunes engine for the level below superbikes so he knows what hes going on about hes even talked about removing my valves and getting them balanced ). Anyway he expalined to him the situation and he replied he needed the crank shaft to completely balance the flywheel.
Do any of you guys know how your flywheels where balanced and if so is removing the crank neccessary for balancing. Or an explanation of how they would be balanced, cause with my kart flywheels i give him the crank aswell and he balanced both to each other.
Do i need to go to this extent to get it balanced or will balancing it without the crank be ok for this aplication.
Sorry it was a bit long guys and thanks for reading.
Matt
Matt
