Old 17-01-2007   #1
Va Va Vroom
Tweedbean's Avatar
Tweedbean has donated!
Removing the ignition Barrel
Wondered how I remove the igniton barrel as my key has snapped off about 1/2 way down?
Got to try jewellery pliers first, but if not im gonna try removing the ignition as see what I can do from them. See if i can shake it out or take it to a locksmiths. Obviously cant move the car otherwise I would take it straight there.
Will it affect my aftermarket immobilier if I remove/change the igntion barrel?
Thanks in advance
James
Tweedbean is offline Reply With Quote Quote
Old 17-01-2007   #2
Va Va Vroom
Tweedbean's Avatar
Re: Removing the ignition Barrel
Just spoke 2 Fiat they said £500 pounds to replace the barrel and all the locks!!!
Seems way too much any ideas as its an urgent problems as I have no car!
Could i just get a key and ignition barrel from a scrappy and fit it?
Old 17-01-2007   #3
Trader Rating: 10
dave has donated!
can you still turn it on? it has to be on to remove it,
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 17-01-2007   #4
I hold up buses
balidey's Avatar
Trader Rating: 1
balidey has donated!
I've not taken a Cinq one off, but a Punto one has two security bolts with a cone head, there is no easy way to grip them, so either weld something on the end (take care about grounding so as not to blow ecu) or you may be able to grind a slot into the end with a dremel (angle grinder will be too big to get close) and then unscrew it with large flat screwdriver.
I hold up buses
balidey is offline Reply With Quote Quote
Old 17-01-2007   #5
Va Va Vroom
Tweedbean's Avatar
No the key wont turn, its set to off, got a mobile car locksmith coming out later £45 to remove, no charge if he cant!!!
Better than Fiats £500 quote
Old 17-01-2007   #6
Trader Rating: 1
cc1 has donated!
You use a centre punch to tap the head of the bolt round.
cc1 is offline Reply With Quote Quote
Old 17-01-2007   #7
Va Va Vroom
Tweedbean's Avatar
Problem sorted now thanks for the response
Old 18-01-2007   #8
Trader Rating: 10
dave has donated!
Quote Originally Posted by jayz165 View Post
tell us how then
Old 18-01-2007   #9
Va Va Vroom
Tweedbean's Avatar
Locksmith with some funky tools managed to pull it out.
Old 18-01-2007   #10
Trader Rating: 10
dave has donated!
did he also make you a new key?
Old 18-01-2007   #11
Va Va Vroom
Tweedbean's Avatar
nah im just gonna use the spare for now, px it soon!
Old 18-01-2007   #12
Trader Rating: 10
dave has donated!
keep the 2 halfs safe, if you loose the spare you can still get a good one made out of them
Old 18-01-2007   #13
J333EVO has donated!
I've removed two ignition barrels from Cinqs, one the original style, one the newer style with different stalks etc like a Sei as the barrels are different when doing my stalk conversion on blue as the steering columns are different, and therefore needed the barrels changing.
I managed to remove both, and reuse the "tamper proof" bolts with nothing more than tools found in the average tool box, didn't take long either.
Aaron.
Cinquecento Abarth 1.4 16V 6speed track toy
Lancia integrale EVO1 Homologation model
MINI Clubman Hampton Edition Cooper SD
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 18-01-2007   #14
Erm...........
cheeqic_nto's Avatar
cheeqic_nto has donated!
So Aaron, do you reckon that the columns are dismantleable? I have play at the top column bush and was wondering if it's replaceable like most f*rds are?
Dirty Yellow Box
cheeqic_nto is offline Reply With Quote Quote
Old 18-01-2007   #15
Quote Originally Posted by cheeqic_nto View Post
The whole column comes out very easily, one bolt on universal joint at the peddle end, two bolts holding top half in place under the steering wheel couling. Depending on which type of column it is, the later type (Sei) is in two sections that just slide over each other.
VW MK5 Golf R32
ignition barrel removal no key, dave Leisure Lounge 27 06-11-2013 23:42
key broken off in ignition barrel marea 2.0 20v stessed eric Security 2 19-11-2006 16:54
(G) Ignition Barrel SkinzCinqSporting Uno 5 16-06-2006 23:33
(T) Ignition barrel fitting seanory1 Coupe 2 23-08-2005 22:53
(T) Remove Ignition Barrel from Switch Eiteews Cinquecento / Seicento 2 06-08-2005 01:35
