Technical Annoying me now...
I'm sure you'll be able to find a scrappers with the original full airbox set up for about a tenner. Could try it for nothing. if that is your problem, get a GSR!:p
Sie
Black 96P Cinq Sporting
OMP Strut Brace, GSR F1i Induction, Pioneer ICE
My mate had a 57i kit on his polo for about a year. The cold air was dragging more fuel through the engine than it needed. Instead of burning in the engine it burnt up inside the CAT. Result a hollow CAT and plenty of backfiring. Just a thought.
Neither. The ECU will require the map sensor to be connected. It tells the ECU when the pressure in the manifold changes. The system will work without it, as yous does, but the ECU will never learn to do without it, so either stick with the jerkiness, or get it attached.
D
Grumpy old git going fast downhill rather than downhill fast!!
It will almost certainly be the MAP sensor if this is not connected.
Another possible problem might be the Lambda sensor. Amanda's Cinq had exactly the symptoms you describe (hesitates for a second, then picks up all of a sudden, most gears - usually in the lower rev range as you accelerate)
I swapped the Lambda sensor over from a 'spare' Cinq I have access to and the problem was cured. Might be worth checking this out as well.
We have luckily managed to keep the sensor off the donor car, so it has run fine since.
MAP sensor is what I would check first, but Lambda is the next option I would investigate....
Regards,
Bruce.
where abouts is the Lambda sensor?
i have a "spare" cinq at the mo too, easy to swap them over?
just looked again and the first wire is connected, my bad :I
Abarth Cinq Sporting in Broom Yellow, The best colour ;)
