im Axle Specialists
Old 10-01-2007   #1
Seciento wont rev
I have seciento 1.1 sporting 51 plate and it wont rev.
it starts no problem and runs great at idle,but as soon as you rev it the revs go to 2000 and no higher and then fluctuate from 2000 to 500 for as long as you rev it.When this happens it brings on the engine management light but it doesnt store any codes and light goes off as soon as you take your foot off the pedal.
Any help on this matter would be great as it is giving me major headaches
cheers for reading and i hope someone can help
Nipper is offline Reply With Quote Quote
Old 10-01-2007   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Seciento wont rev
Sounds like a Throttle pot problem.
Check it with a meter.
D
Old 10-01-2007   #3
Trader Rating: 1
99sei has donated!
Bush Shootout Champion
think rally cinq is on the right line
other thing is tdc sensor - my friend had this recently
check out the idle control sensor first though
Quote Originally Posted by 99sei
im ginger and special
and now im terrorising the roads in my cinq
99sei is offline Reply With Quote Quote
Old 10-01-2007   #4
Hi guys i have checked the throttle valve and all seems to be well there.
By the tdc sensor do you mean crankshaft sensor are these the same thing ?If so what was the problem your pal had (99sei) ?did changeing the sensor solve the problem?...
Old 10-01-2007   #5
Blast some carb cleaner on the TDC sensor to see if it makes any difference.
Mine get's clogged up to hell because i can't be bothered to put the drivers side inner arch back on the car, but a blast of car cleaner sorts it.
If it's not that then yes it could be the throttle potentiometer, or the tb butterfly sticking. Take the air inlet box off and take a look, if it moves ok with the cable then it's the TPS (throttle potentiometer switch) prices aroun £34 form a good motor factors.
Đę√їǾŪĐę√їŁ
Black Cinq Sporting SOLD Gone but not forgotten!
Replaced with a V6 Monster!
frenchwood is offline Reply With Quote Quote
(T) Fitting Sporting Rev counter to 899cc?? Matt925 Cinquecento / Seicento 7 07-01-2013 09:42
(T) my mk1 55 rev counter 5000 rpm ?????????? amitoha23 Punto (Mk1) 2 10-06-2006 20:53
1.9 JTD engine won't rev over 3000 rpm Chas Uno Lets Talk FIAT 4 31-03-2006 19:29
(T) Punto mk2a Rev Counter... fannon Punto (Mk2/2b) 0 28-02-2006 19:03
(S) Uno instruments pods with rev counters on Ebay Chas Uno Uno 11 14-03-2005 11:07
