Thread Tools
Old 24-03-2004   #1
Panda Owner
MikeWhitcombe's Avatar
MikeWhitcombe has donated!
Italy
Dials
Any way of fitting a rev counter (cheaply, from one from a scrappy for instance) to a cinq that doesn't currently have one? Are the connections there?
CINQUECENTO DASHBOARD CLOCK WANTED - PLEASE PM ME
MikeWhitcombe is offline Reply With Quote Quote
Old 24-03-2004   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
why not fit the standard sporting clocks ,you need to run a feed from the coil which im sure some of the guys n gals will help with
The Fiat Cinquecento
Fun While It Runs
Old 24-03-2004   #3
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
the 899cc cinq's don't have the wiring for a tach, simply because the sporting tach gets it's signal pulse from the ECU of which it can't get from an 899cc ECU[xx(]
MrDerv is offline Reply With Quote Quote
Old 24-03-2004   #4
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Its the same type (16F) of ECU in bothe the cars...so probably has a common architecture, so if yu can find what wire the pulse is send on in the Sporting, you could always put the wire in!
Nicely, Haynes chose to omit that one!
Tom (AofB)
GrpN Catback Exhaust system is here...just need to get the bleeder on now!!
arseofbox is offline Reply With Quote Quote
Old 25-03-2004   #5
Panda Owner
Italy
Woah Woah Woah! Explain:
  • ECU
  • Pulse
  • 16F
Old 25-03-2004   #6
Trader Rating: 3
The ECU is the fuel injection system's brain simple as. All Cinqs made from 1995 onwards use the Marelli Weber 16F ECU model of these, so If the ECU in the Sporting produces a pulse for a tacho, so will an ECU in an 899cc!.
But still, a lot of tachometers take a feed from the ignition coil..problem is, most 4 cyl engines use 1 coil for all the cylinders, but the Cinq nicely uses 2, so it (the system) produces half the number of pulses than a typical system.
Tom (AofB)
Old 25-03-2004   #7
Panda Owner
Italy
Pulses?
Mine's 94/95 M...
Old 25-03-2004   #8
Trader Rating: 3
Well, I know that uses a 6F type ECU, which should be simialr... the wiring for both is identical..
Id have to find which wire is the coil pulse one..
Tom (AofB)
Old 25-03-2004   #9
Panda Owner
Italy
Okay. I don't know anything about ECUs or Pulses or stuff so I'd need a sackfull of help with doing such a thing!
Old 25-03-2004   #10
The Negotiator has donated!
I use the old "engine noise is proportional to the number of RPM" method.
I.e. RPM = k*intensity of engine noise
Where K is an abitary constant which varies between cars
I would love a RPM counter but the complications of it far outweight the use of it IMO.
Best of luck however.
Paul
My first signiture (a lot of thought put into it): If you can't find the switch to switch your fogs off I am sure I can help you! Damn fogs.
The Negotiator is offline Reply With Quote Quote
Old 25-03-2004   #11
HP
I was only doing 80...
HP's Avatar
HP has donated!
Rev it till it cuts out (6200 in an 899) then change up just before then next time.
Pete.
1242cc cinq,turbo cinq,Cinqs&Seis Yahoo group,Clubcento
HP is offline Reply With Quote Quote
Old 25-03-2004   #12
Trader Rating: 3
Hmm, has it got a rev limiter or is that when the head gasket goes bang?
Tom (AofB)
Old 25-03-2004   #13
Cento Boy
surfin_fella's Avatar
surfin_fella has donated!
my 899cc took a battering. They run forever. A rev counter scared the hell outta me when I got my Sporting!!!
Sie
Black 96P Cinq Sporting
OMP Strut Brace, GSR F1i Induction, Pioneer ICE
surfin_fella is offline Reply With Quote Quote
Old 25-03-2004   #14
Panda Owner
Italy
I only want one cos it looks cool and just out of interest... i'm bored of my dash now.
Old 26-03-2004   #15
HP
HP's Avatar
HP has donated!
899's cut out at around 6200, Sportings at around 6900 - 7200.
Pete.
Thread Tools
(S) Create your own dials!! MrDerv Cinquecento / Seicento 25 09-05-2007 16:26
(S) white dials for a fiat brava 1.2 16v bravaboy Bravo / Brava 5 19-12-2006 16:48
(S) Yellow Dials MotorWorldChink Cinquecento / Seicento 10 07-06-2004 21:19
Bravo Lockwood Dials bravaaidey Latest News 4 19-05-2004 04:03
(T) Dashboard Dials Don't Work MarkH Marea 2 13-03-2004 04:09
