yes, mines running nicely. fully road legal. very driveable. quite nippy - just needs further tweaking to the maps
Cool, could I take your file when I get mine all fitted to start from?
Cheers Asteris,
as far i can see thought, that article talks about driving several coil packs at different times, for >4 cylinders running wasted spark.
What i want to do is run a 4 cylinder wasted spark system, that normally has 2 spark outputs (1+3)(2+4), but splice it so i run 4 coils in wasted mode.
Kind of hard to explain exactly what i mean, so i may just fit the COP set-up to my running seicento ecu, splicing wires, and see if it runs
It could work in which case my idea is verified, or it could result in £200 of COP plugs and a Seicento ECU destroyed :devil:
I'll try it on the weekend if I get chance....wish me luck lol
Kristian
Read a couple pages lower, at the link i gave you, it says "Driving two coils from the same spark output e.g. 4cy COP (wasted spark format) 6cy and 8cy COP"....
http://www.msextra.com/ms2extra/MS2-Extra_Ignition.htm#2coilscop
