Technical Clutch pedal
Stoke-On-Trent
Right hoppin someone can help
ive got a fiat cinquecento 900 sx p reg and have had a clutch fitted about two months a go now but the pedal in my opinion is to stiff as it used to be light on the old clutch have taken it back to the garage but they say it is nothing to do with them they just "fitted it correctly" end of conversation.
someone please help as i'm learning to drive in it at the mo and most of my gear changes are jerky which is annoying
The younger modder
did they replace the whole clutch..? if it was replaced it should be light as a feather... mine got changed not so long ago and its very lite. if i was you get a secound opinaon from another garage.. you nevr know the first garage could off fitted it wrong.........
It certainly sounds as though something is fitted wrongly. It could be the clutch cable routed incorrectly, the clutch slave arm not in correctly or the whole clutch assembly a about t. Either way, my daughter can drive a cinq smoothly and she's under 5 feet tall.
D
Grumpy old git going fast downhill rather than downhill fast!!
