Sucess !!!!!!
Fitted new Lambda sensor, second hand MAP sensor, new MAP to Throttle Body vacum pipe and connectors and a new set of NGK plugs.
Followed the Haynes book of stuff with the 20 min disconnection of battery, followed by running the engine at tickover until the cooling fan comes on for the second time... etc...
The engine is now fantastic - very smooth and responsive - Missfire has gone, Injector light comes on with ignition key and then goes out in a couple of seconds not to be seen again....
Please find below the correct Bosch part number for a Lamda sensor to fit a Cinquecento and Seicento...... The only difference between the two (according to Bosch Technical Helpline) is that the Cinq one has two twin connectors, and the Sei has one quad connector. They are both Four wire sensors - 2 x white, 1 x grey & 1 x black.
Please follow the cable from your Lambda sensor to the loom - Under the MAP sensor to see if it's the twin or the single connector. Also, before removing the Lambda sensor - give it a good soaking in WD40, AC90 or similar - then make sure the exhaust is warm as this will help.
Twin connector :- Bosch 0 258 003 222
Single Connector:- Bosch 0 258 003 579
