Old 10-03-2004   #1
Chris
Trader Rating: 2
Bushboy has donated!
My fan doesnt work!
right... i ran my car upto the 110degrees mark today and decided to stop and check to see if the fan came on. popped the bonnet and stood and watched for about 5 mins and the fan didnt come on once even tho the temp was just outside the red.
Ive only ever noticed the fan come on once before and never since. anyone any ideas what i could look at? could be a loose connection to the fan etc or something like that but any other ideas?
Bushboy is offline Reply With Quote Quote
Old 10-03-2004   #2
HP
I was only doing 80...
HP's Avatar
HP has donated!
airlock, dodgy fan and / or switch, blocked radiator, loss of pressure somewhere, faulty thermostat.
Pete.
1242cc cinq,turbo cinq,Cinqs&Seis Yahoo group,Clubcento
HP is offline Reply With Quote Quote
Old 10-03-2004   #3
Chris
Trader Rating: 2
airlock? Will check the fan for dodgy connections and so on soon.. well in a min actually. how can i tell if the radiator is blocked? Also i think my coolant bottle cap has a slight leak in it. im getting the one off ghostWKDs write off cinq. but surly if the meter in the dash knows the car is really hot then the fan should turn on regardless of lack of presure?
Old 10-03-2004   #4
Chris
Trader Rating: 2
right... ive just let it sit there and run up again to see if the fan does defiantly come on or not and it did for about 1 second when it got to around 110 degrees. there was water leaking out of the coolant cap (only happens when the car gets very hot) so i presume this is where the loss of presure is. Hopefully ghostWKDs cap will sort the prob (provided his isnt faulty too!)
Old 10-03-2004   #5
taffy git
gaz.d's Avatar
Trader Rating: 2
gaz.d has donated!
*hands up
ive had that problem, the seal on the cap perished so it was gushing all over the engine bay, new cap bout 3.50
Seicento Sporting, Modified Front Bumper, Saxo Custom Spoiler, Abarth Side Skirts, Bad Boy Bonnet, Afterburner Rear Lenses, 4" Powerflow Exhaust System, Abarth 14" Alloys.
IN THE PIPELINE:
-40mm Drop
Check out my site: http://badboygaz.mysite.freeserve.com
gaz.d is offline Reply With Quote Quote
Old 10-03-2004   #6
Chris
Trader Rating: 2
the seal looks fine tho but obviosuly isnt. where can i get the cap from? i havent ever seen a fiat dealer around here...
Old 10-03-2004   #7
halfrauds have them, but when i looked the only one they had was 8, i thought that was a bit much so went down the scrappy cus i needed some other bits too and they charged me a 5 for that and a wiper motor
dawozere is offline Reply With Quote Quote
Old 10-03-2004   #8
Chris
Trader Rating: 2
just been upto my local fiat place (not very far actually.. a glyn hopkin place) and there comp said they had 1 but she couldnt find it so they have ordered me one and i can get it on friday. 3.67
Also, are the caps for the sporting and the normal cinq the same? i forgot to mention i had the sporting [:0]
Old 10-03-2004   #9
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
'Ang on
***Roots on Parts CD, tripping over own feet in process***
Yep...clever bit of engineering too, its shared with most things on this disc!
Tom (AofB)
Snapped exhaust flexipipe becoming GrpN ASAP!
arseofbox is offline Reply With Quote Quote
Old 11-03-2004   #10
Chris
Trader Rating: 2
yay! cheers arse...
oh and i also just went to halfords to check but there comp said thery had 2 in stock but they couldnt find them either. think ill just go get it from fiat on friday then
Old 11-03-2004   #11
Chris
Trader Rating: 2
well me and arc have come to the conclusion that its probably the fan switch which is 8ish from fiat but is an arse to fit!...
Might see if they have any when i go to collect the radiator cap.
Old 11-03-2004   #12
Cento Boy
surfin_fella's Avatar
surfin_fella has donated!
I've just had just about my whole cooling system replaced this week. seems to have sorted mine out. Expensive job though:(
Sie
Black 96P Cinq Sporting
OMP Strut Brace, GSR F1i Induction, Pioneer ICE
surfin_fella is offline Reply With Quote Quote
Old 11-03-2004   #13
Chris
Trader Rating: 2
i can imagine!
im just hopin it aint the fan thats buggered cause thats 60! i dont even wanna know what the radiator is!... although it might be a good idea to do the radiator too...
but ill try the cheap stuff first :p
the fan does spin up when its told to... which is for 2 seconds when it hits 110 degrees so in theory, the fan still works.
Old 11-03-2004   #14
Cento Boy
could be the fan switch?? I'm not sure but I'm sure some of the Cinq Techies could answer that for ya
Sie
Old 11-03-2004   #15
Chris
Trader Rating: 2
yeah thats what me and arc concluded. gonna pick one up tomorra at Glyn Hopkin when i goto get my new radiator cap... provided they have them that is.
work + nice weather + going out = me dead! arc Leisure Lounge 32 02-08-2004 03:30
Oi get back to work!!!! sammiboo Leisure Lounge 31 17-07-2004 18:16
Cheaper petrol? Will it work? bazd123 Leisure Lounge 3 26-05-2004 23:49
(G) TMC won't work in UK poggy Ulysse 3 31-01-2004 22:31
(T) dash instrumentation doesn't work sonic Punto (Mk2/2b) 6 26-01-2004 06:47
