Cheers Asteris.
I am familiar with both locking nuts and reverse bolt threads.
The one side of the bolt works fine and threads ok, all the way in. The other side doesn't screw in hardly at all, this is a reverse thread so I have to turn anti-clockwise for it to move inwards.
That is the problem though... The right hand side, reverse thread bolt will NOT screw in very far at all! Thats as far as it goes! I used a LOT of force to try and move it in further, and it was not budging. I remove the bolt, oiled the thread, cleaned the thread with a cloth, but to no avail.
The ONLY reason you see in my picture the one side screwed in further than the other was an attempt to make it fit! With the one side screwed in pretty much all the way, it is
just short enough, with a bit of persuasion, to fit over the top mount bolts, but once on, there is no play in the left hand/reverse thread bolt to tighten it at all.
If i were to center the bolt; a) it wouldn't fit over the strut bolts, it will be too long and b) if i were to drill the holes so it would fit on, I
still couldn't tighten the brace at all.
I'm sure the thread/nut on the one side is def broken! And without a LOT of messing about, and then not being able to adjust it, its not worth the hassle. Im sure its faulty.
Cheers anyway
Kristian
