Old 07-11-2006   #1
Quarter Panel fitting
a mate of mine is thinking of buying a cinq to use as a run around for work and things,the one he has been offered has a damaged O/S wing,are the wings welded to cinqs? can the replacement be bolted on just,or what?
thanks
garyaird11 is offline Reply With Quote Quote
Old 07-11-2006   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Quarter Panel fitting
Fronts are bolt ons, rears are weld on from the roof join down.
D
Old 07-11-2006   #3
+ if its a pattern panel it will need a fair amount of tlc to make it fit.
Van Aaken High Boost Turbo Cinq In Caribean Orange, Highly Modded
Whiley is offline Reply With Quote Quote
Old 08-11-2006   #4
as said above front wings are held on with six 10mm bolts and two hex bolts whcih also hold the bonnet hinges on and they are reasonably easy to do the hard part being lining them up properly which many people dont seem to do these days
rear quarters are a whole different kettle of fish you need to weld for a start and to a very good standard not just a go for it diy'er and the old rear quarter is cut off and the new one joined on about three quarters up the C pillar and half way up the b pillar and about 10cm in on the door cill and most of the time an inner arch is required but again many people rarely do this including garages
id sugest genuine parts for both from dealers they arent expensive and the fit is a whole load better
wayne
Mincento Autospares-For Fiat and Alfa romeo spares, message via PM and ill get back to you
The younger modder is offline Reply With Quote Quote
(G) Dent in rear quarter panel Shauncorwyn Grande Punto 5 24-09-2006 08:40
(T) Rear quarter panel the beasto Cinquecento / Seicento 8 09-09-2006 10:52
(G) Rear quarter panel KeithT Punto (Mk2/2b) 0 08-01-2006 19:56
(S) Rear quarter panel? Cazza Punto (Mk1) 4 19-12-2003 00:38
(G) Rear quarter panel? Cazza Punto (Mk1) 0 18-12-2003 18:46
