Old 05-11-2006   #1
air temp sensor
any one on here know the retrospective resistance to temp figures for testing the air temp sensor, or the base test number at 20 degree c
nogin is offline Reply With Quote Quote
Old 05-11-2006   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: air temp sensor
What car?
D
Old 05-11-2006   #3
Greece
Re: air temp sensor
Same as the water temp sensor, 10K to 300 Ohm, 0 to 80 degrees.
Asteris is offline Reply With Quote Quote
Old 07-11-2006   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: air temp sensor
You have pm, but for the benefit of other forum users, the results from the Norwegian jury are:
0 degrees 10000 ohms
10 degrees 7000 ohms
20 degrees 4000 ohms
30 degrees 3000 ohms
40 degrees 1500 ohms
80 degrees 330 ohms
all approximately
D
(T) Oil on MAP Sensor & Sensor wires scorched?! DaveX Stilo 6 09-09-2006 08:17
(T) coolent temp sensor 5577rob Punto (Mk2/2b) 3 24-05-2006 00:23
(T) Air Pressure Sensor kevhky Stilo 8 13-04-2006 23:13
(T) 1.6 elx engine temp. high when air con is on. apai Marea 1 02-08-2005 22:04
(T) Injector Warning Light / Temp Gauge Probs chuck Bravo / Brava 20 29-10-2004 00:06
