General fan blower system not working
Donnalf25
my fan system on my cinq is faulty. No hot or cold air is coming through at all. I have changed the fuses (the blue 15 & white/clear 25) but it still doesnt work.
please can anyone help? what should I do next?
your heater system may have an airlok near the battery under the bonnet you will see 2 pipes going into the bulkhead fibre stuff above one of them it will have a bleed screw u need to warm the car up 1st and leave it running, undo the nipple and let some of the air out, it water is just comming out then your system may be blocked and need flushing out, if so just take the top hose of the radiator and stick the hosepipe down it and seal with your hands then put the tap on full blast and wait for thewater to become clear whats comming out of the radiator.
I've worked out that you can remove just the fan assembly without having to remove the whole heater box assembly.
You need to undo the wiper motor, but after that the fan housing is held onto the heater box with four small screws which can all be got at, in a fashion.
D
