Old 03-11-2006   #1
Trader Rating: 3
gazzaman2k has donated!
Post boost/vacuum pipes?
see the attached picture the bit on the turbo thats circled am i right a pipe needs to come from this to the actuator on the turbo
also where abouts do boost guages/fuel regulators join into this?
is the picture correct? that the turbo + actuator is totally seperate curcuit to the others or do i have to find a 5 way splitter?
help me please not clued up with turbos yet lol but learning
gaz
p.s bet you all wish u had good paint skills like me
ID:	20432   Click image for larger version
Project Seicento
gazzaman2k is offline Reply With Quote Quote
Old 03-11-2006   #2
Winning
GhostWKD's Avatar
GhostWKD has donated!
Re: boost/vacuum pipes?
Yup turbo is closed loop, although if you have a bleed valve that goes in this loop, so i'd imagain the boost controller will want in there somewhere...
Then the map/vacuum line, you dont want a 4 way splitter or a 5 way splitter, you want a couple of 3 way splitters to fit in line with 1 output each... will see if i can find a pic of mine for you
GhostWKD is offline Reply With Quote Quote
(T) Removing coolant pipes from Throttle Body andyr Punto (Mk2/2b) 1 15-08-2006 21:16
(T) 2.4TD Oil cooler pipes al_scott Marea 6 03-06-2006 21:07
brake pipes recall waltgreen Lets Talk FIAT 3 04-05-2006 12:00
Brake pipes - MOT fail Fast Finger Lets Talk FIAT 3 15-06-2005 21:57
(T) break pipes punto team Punto (Mk2/2b) 15 21-11-2004 10:39
