Technical Dot 5.1 Brake Fluid in Cinq Question
Well, I'm gonna sort it out, they work OK, but come mot time, I'm sure it won't pass.
I have rear shoes to fit this weekend, so I will check the adjustment then, could just draining and changing fluid caused that to alter then?
When I'm there I will re-bleed with the fluid I have left, and hopefully that will sort it. If not, I'm draining again, and going back to some DOT 4 as that would be the only other thing thats changed.
Cheers,
Kristian
