General Wheel Spacers
Looking at an empty Glass
If any of you guys are on the look out for spacers for your wheels, in my search I came accross a guy that can supply seemingly any size of Hubcentic spacer (Including really odd sizes) they also come complete with longer bolts or bolt throughs if needed and at a really good price! they also do other Alloy wheel bits, stud conversions, PCD adapters etc
They are called Jackspratt automotive you can either email them on [email protected] or telephone 01554 810929 / 07779 315343 ask for Andy they take cheques and paypal
i wasn't sure which bit to post this in but i'm sure a mod will move it if its in the wrong place..
Yep I got my spacers from him,
My house is really dificult to find and the courier cocked up the delivery (left it somewhere else!) I emailed Andy and He couldn't do enough to make sure they were delivered ASAP, they were delivered the next day!
He sells stuff through ebay but has no web site that I know of though.
They do Spacers , extender bolts, stud conversions, wheel nuts, extender studs, PCD conversion adapters and other suspension stuff
They are very good and really helpfull just email Andy if you need something
tidus said:
he dont do 10mm hubcentric.
You'll find nobody does. A 10mm spacer is too thin to be hubcentric and still retain the required strength.
The thinnest I found were 15mm are Techno2 sourced from Walkers, look carefully at the machining and you'll see why they can't be made thinner
Cheers, John
Fiat do a 10mm hub centric spacer, it was standard fitment to Sei Abarth's with 14" wheels.
About £32 from fiat.
Aaron.
I believe that this is correct code, this is per spacer, so X2.
46532804 - SPACER
Availability: - Product orderable
Family: CX01 - SUNDRIES-BRAKE SYSTEM
Macro-family: G
Discount code: B
Minimum quantity per package: 1
Unit of measurement: Num
Weight (grams): 900
Listed price: 14.21 GBP
Price including taxes: 16.70 GBP
J333EVO said:
Fiat do a 10mm hub centric spacer [snip]
I stand corrected... In fact i've just ordered some new wheels (see other thread) which means my 15mm spacers will only be used with the std sporting wheels, and I was just wondering how to space the new ones (y)
John
i dont have a clue about cars, but i know i need 20mms at the front and 10mms at the back. in motor-world i was quoted at least £25 a corner for spacers and longer bolts. what sort of prices does this guy do? its too late to call him and i thought i might ask you guys just in case you can give me an answer before tomorrow morning
Well look up the thread there is already a price for a pair of (the only) 10mm hubcentric spacers amde by Fiat, then Fk Automotive 20mm spacers are £40 a pair http://www.performancedriven.co.uk/shop.product.0.asp?ProductID=5002&CatID=119 there are others of course;
http://www.performancealloys.com/alloy_ … pacers.asp
http://www.rallydesign.co.uk/catalog/in … ?cPath=731 for studs/nuts
http://www.motorsportworld.co.uk/ (look under Eibach pro spacers)
http://www.performancefx.net/wshome.htm
Couple of folk on ebay do them and may be able to help http://search.ebay.co.uk/_W0QQsassZfireturkQQhtZ-1QQfrppZ50QQfsopZ1QQfsooZ1QQrdZ0
