Can someone tell me how and where the oil feed is connected to the block for the turbo, how the pressure is regulated and possibly the thread sizes?
-Thanks Andy
-Thanks Andy
M@nticore said:If you look carefully you'll see that the top one is after the filter and the bottom one is before the filter, so if you use the top, you would get a filtered oil supply and if you use the bottom it is unfiltered oil.
custard said:if im at the turbo tomorrow i'll double check but i would go turbo then cooler to cool the oil post turbo.
then into the sump
if no cooler then direct from the turbo to the sump
custard said:
if you brighten this up you may be able to see
