Technical Rear Wheel Bearings..
Puntodan
Sutton, Surrey
Ok car (cinq sporting) is nearly ready for the mot after a new cambelt alternator and exhaust but after taking it for a drive there is now a louf]d humming noise from the rear, sounds like the wheels bearings are shot!
Went to the local motor factors and they are £60 each plus the vat!! Accoring to them you have to replace the whole hub!? Is this true? If so is there anywhere that does them cheaper or is there a way to check to see if it is the bearings that have gone!?
Many thanks!
Dan
Sounds like a bit of a nightmare, but not to much of a problem, just for puntodan incase it happens to him
arc said:
ended up cutting into it a little and then using a screwdriver and hammer to force it to rotate round the shaft to loosen it a tad, then got the screwdriver in behind, opened the gap - then wider with a chisel and then used some puller/jaws things that pulled it right off.
Nice one guys £25 each is a lot more reasonable than £60 each! Looking in the haynes manual it looks like it is quite straight forward to do, just hope the drums come off ok and doesn't leave me with a nightmare hiding under there!
Dan
