Technical How to replace the o-ring in the diff?
woj
Established member
Halmstad
Hello,
Since in this area of the engine I really don't know proper English names for things, I will use a picture (see below). After some consultance and looking into the matter, I think the o-ring in the diff leaks (as you can see on the picutre, it's a bit messy - and this is after cleaning up). The o-ring I talk about is marked with A and a red line (although probably it actuall sits a bit deeper). Now two questions:
1. What size is this o-ring? Does this have to be a special one from fiat, or a standard one (properly sized) will do?
2. Can I replace it without taking the gearbox out? My plan of attack would be the following (but I am not sure I interpreted everything correctly in the service manual).
(a) I drain the gearbox
(b) I take the drive shaft out (yes, I know, it only sounds simple) and take the exhaust out of the way.
(c) I take element B (what's this damn thing called) out. According to my understanding it should just slide out, or am I totally wrong?
(d) I replace the o-ring (that I guess will be tricky and brige will be needed for good access).
(e) I put everything back together, not forgetting to put new gearbox oil in
Or am I absolutely off... Any help on this would be greatly appreciated.
Shoot, I of course meant zimmering, not o-ring, slip of a tounge... /Woj
I mean zimmer-ring - the metal ring with rubber sleeve. The stuff that you have to hammer in gently... /Woj
SHAFT SEAL..
Ref: Item B. I think there's a circlip that retains this in place at the spline end.
This should compress as you pull out the shaft (B). (B) should pull out by hand but if not then It's a two man job, One to use levers and the other to hit (B) with a hammer on it's side to help move it.
woj said:
Hello,
The shaft seal will have a number on it which I think refers to It's dimensions etc. You can take it to a bearing supplier and they should be able to supply you with one.
cc1 said:
SHAFT SEAL..
This is what we have been speculating about with my brother looking at the schematics of the gearbox/diff. The level of detail on the schematics is too small to be able to tell whether there is something at the end that locks item B in place. In the gearbox dissassembly section the manual simply says - "first step: take item B out, and then blablabla..." But the manual assumes the whole gearbox is out - now the question is whether I can really mess things bad if I try to take B out with the gearbox in place. More importantly - will I be able to put it back nicely...?
Reg. the numbers on the shaft seal - surely once I have it out I will know what size/type it is. But I would prefer to have it in hand before I start taking things apart...
Cheers,
Woj
Cheers,
Woj
The FIAT part number is 40004620 £3.77
I'm using the WKL book for the Seicento by Jozef Zembowicz and the Cinq one. The diagram seems to show a clip, and remember seeing this clip on a shaft but can't remember when. I'm shure the whole thing came out still attached to the drive shaft (by accident) and not much oil. But there probably wasn't much oil in the box anyway.
Is there a webpage one can check those FIAT numbers??? That could be very useful for future reference...
I have the WKL book for cinq (a translation from french), but it seems I should get my hands on the Zembowicz one too. Thanks a lot for the part number, just I hope the left and the right one are the same :D
If it came off by accident then it should be doable on purpuse I guess. I was just under my car finishing things up, and it is definetely locked in somehow, cause it moves within circa 1mm range and then just stops (this is with all drive shafts and everything in place).
Thanks cc1, that has all been very useful.
/Woj
OK, somebody, I need help here - I got this part, but it's the wrong one :mad:
The shaft seal I took out of the car is slightly smaller than the one I got from Fiat, otherwise looks the same. So now I wonder if they are the same on the left and right, or different? I need a part number for a diff. shaft seal that goes on the right side for a CC Sporting. Given of course the one above is not right, it could be right, just somebody messed something up in Fiat...
BTW :cry: I have the whole front suspension apart, one drive shaft, and the exhaust manifold and my car is nowhere near driveable...
/Woj
