Thread Tools
Old 16-08-2006   #1
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
aerial problem
Not really a problem as such but more of an annoyance.
The reception to my HU is currently very poor. The aeriel is currently sat pretty much level with the sunroof.
Once the aeriel is raised however, the reception is improved.
However in any type of road conditions, be it motorway or in town, a slight breeze or a slight burst of speed, and the aeriel is back to the horizontal position, thus returning to the poor reception.
The actual mechanism in which you raise and lower the aeriel seems very loose and was wondering what a solution was.
Is there a nut under the plastic protection bit i which i need to tighten? Or any adaptions i could do?
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
Old 16-08-2006   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: aerial problem
i would guess the actual ridges(i assume)are worn allowing the aerial to fall.
could try tightening the nut which will be inside the car or probably fit another aerial.
if you do remember to attach a cable ot the aerial cable as you withdraw it so you can pull the new aerial cable through
Old 16-08-2006   #3
Formerly mog1571
Luke M's Avatar
Trader Rating: 2
Luke M has donated!
Re: aerial problem
what about one of those booster things?
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline Reply With Quote Quote
Old 16-08-2006   #4
custard's Avatar
Trader Rating: 1
Re: aerial problem
not really needed as its just a worn aerial mount.ive shortened my aerial and still get no reception problems
Old 16-08-2006   #5
kritip's Avatar
Trader Rating: 4
kritip has donated!
Re: aerial problem
I've been thinking about this myself. I would like no visable ariel, not a crappy shark fin, or the standard.
The pillars to the side of the drive are very easy to remove, and an ariel would fit in there easy i think. Perhaps moving it to a new position, like in the pillar will alleviate your probs, and give you a nice look?
Will be a few weeks before i get round to this job but it does seem feasable to me.
Otherwise, you can buy a new ariel from shop4parts. Drop them a mail, and see if its the complete assembly??
Another alternative, is to raise it to max height, or where you like, and get some super glue, and run a small amount down the ariel monut. Will dry in a min or so and keep it standing tall
Kristian
kritip is offline Reply With Quote Quote
Old 16-08-2006   #6
custard's Avatar
Trader Rating: 1
Re: aerial problem
could always try just running an aerial lead extension cable along the roof lining?
perhaps give a decent reception so oyu could do away with the external mast.
or go DAB
Old 16-08-2006   #7
***** Friendly
serin has donated!
Re: aerial problem
which kind of aerial is it, as the cinqs had to types, and the sei might use a compleatly different one
mines the same tho it either stays up or down and nowhere in between
serin is offline Reply With Quote Quote
Old 16-08-2006   #8
custard's Avatar
Trader Rating: 1
Re: aerial problem
both my cinqs can be set at any angle??
Old 16-08-2006   #9
***** Friendly
serin has donated!
Re: aerial problem
Quote Originally Posted by custard
yup, they all can originally, but on my cinqy its all old an worn, so it dont
i tried getting one off of alex22's scrapper, but thats compleatly different as its one of the later cars
that to can be set at any angle
Old 17-08-2006   #10
kritip's Avatar
Trader Rating: 4
kritip has donated!
Re: aerial problem
could always try just running an aerial lead extension cable along the roof lining?....
or go DAB
DAB horrible horrible horrile
In the roof lining would probably cover most of the reception, but i think in th epillar will be ok. If I'm bored tommorrow, i'll give it a go, just need to cap the top properly o prevent leaks
The other annoying thing I found when the ariel is at it lowest, it can tap the roof...ggrrr...I have to have it like that when i have my roof bars on, can't imagine it all the time
Kristian
Old 17-08-2006   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: aerial problem
Quote Originally Posted by kritip
Kristian
Eh, no. DAB superb quality, thanks.
D
rallycinq is online now Reply With Quote Quote
Old 17-08-2006   #12
kritip's Avatar
Trader Rating: 4
kritip has donated!
Re: aerial problem
http://www.hydrogenaudio.org/forums/...c=46371&hl=DAB
Each to thier own, but I have heard a few DAB sets, and have been most unimpressed to say the least. Give me a decent FM reception any day.
Kristian
Thread Tools
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto (Mk1) 8 10-09-2010 09:17
(G) Punto 3 door seat problem Reaver23 Punto (Mk2/2b) 4 04-09-2007 13:03
(T) Injector Problem! Help! Thanks fear Bravo / Brava 4 19-11-2006 20:11
(T) Windscreen wiper motor problem Thomas P Uno 10 23-08-2006 21:04
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 19:58
