General compression test
Lets end this and tell you how the garage way is. There is a "dry" and "wet" test. Dry is done at beginning with open throttle and pressure guage. When readings have been done, you put a small teaspoon of oil down each plug hole to do a wet test. This is to test for ring failure. If the guage does not read higher, rings/gasket is leaking. Simple and takes 15 mins to test for compression/leaks.
Andy.
Oh to test head gasket, coolant header tank should be pressurised to 6 bar to test head. If it cannot hold pressure, it will show leak. Either a pipe, joint or head gasket. And, if you have a friendly MOT garage, ask him to put his emission sniffer in your header tank to smell the tank for leaks. (y)
Andy
Andy.
exactly as its says on the back of the gunson tester i got to check the turbo's compression
Andy.
is that with one plug out or all of them?
oh thanks for the info too (y)
One plug at a time. Does not matter as other cylinders will not effect the one you are checking.(y)
Andy.
it doesnt matter compression wise, but you dont want the other 3 plug holes to suck any dirt in during their intake stroke. that could block an exhaust valve or damage a piston ring. there's probaly all sorts of crap lurking around the plug holes. i usually blast the bits off with my compressor before taking a plug out, just to make sure.
Liam said:
Sorry, didn't read all the thread, was too much bickering etc on it but for what it's woth, when doing compression tests I remove one plug at a time, screw in the guage, turnover and record readings, repeat for all cylinders then put a small drop of oil down each bore to remedy and possible sticking pistons rings.
Liam
by bore do you mean the spark plug holes?
now the head is off could i put a drop down the valves? or would people recommend not doing this?
got a pic of my head, dont look in bad nick, anything i should check for whilst its off? how do i check for burnt piston rings and bent valves? (im still learning mechanics so be patient with me :eek: )
[/IMG]
When the head is still attached you drop some oil down the spark plug holes and this goes into the cylinder bores and can unstick a sticky piston.
Liam
