Old 12-08-2006   #1
Clubcento Member
CaneyJ has donated!
Setting Timing
2 Quick Questions
1. Which way round does the engine rotate again? Do the pulleys rotate clockwise or anti?
2. Also, there is a white line across the belt, does that line up with anything.
I believe the notch in the pulley is aligned with the cylinder head and the bottom pulley mark is aligned with the corner edge lip of the crankshaft pulley shroud?
CaneyJ is offline Reply With Quote Quote
Old 12-08-2006   #2
Banned
Oldschool has donated!
Re: Setting Timing
When you look from cylinder no. 1 it is rotating clockwise. If there is no arrow on then place the belt that you can read the numbers and letters from looking at cylinder no. 1 normally.
Align the cam pulley mark with the notch at the end of the cylinder head. The crank pulley has got a notch too. The white stripe that lines up with the groove of the belt has got to be lined up with the pulley that has got the mark on the tooth and vice versa on the other pulley. To align it with the crank pulley you might have to turn the cam pulley a bit. This is okay to do.
Oldschool is offline Reply With Quote Quote
Old 12-08-2006   #3
Netherlands
Re: Setting Timing
Don't Underestimate The Power Of TurboCinqy !!! About 160 BHP 230Nm Torque
TurboCinqy1250 is offline Reply With Quote Quote
(G) Timing Belt Replacement lightweightmick Panda (Classic) 16 10-09-2010 11:03
(T) Timing problem Kobus van Zyl Uno 11 08-06-2006 11:57
(G) how to change a timing belt.. christopher watson Panda (Classic) 10 02-01-2006 20:29
(T) Punto Sporting 1.6 Timing Belt Setting headON21 Punto (Mk2/2b) 5 04-05-2005 09:27
(T) Timing Problems 1.8 16v sparks Punto (Mk2/2b) 1 18-02-2005 15:08
