Technical Setting Timing
CaneyJ
Clubcento Member
2 Quick Questions
1. Which way round does the engine rotate again? Do the pulleys rotate clockwise or anti?
2. Also, there is a white line across the belt, does that line up with anything.
I believe the notch in the pulley is aligned with the cylinder head and the bottom pulley mark is aligned with the corner edge lip of the crankshaft pulley shroud?
When you look from cylinder no. 1 it is rotating clockwise. If there is no arrow on then place the belt that you can read the numbers and letters from looking at cylinder no. 1 normally.
Align the cam pulley mark with the notch at the end of the cylinder head. The crank pulley has got a notch too. The white stripe that lines up with the groove of the belt has got to be lined up with the pulley that has got the mark on the tooth and vice versa on the other pulley. To align it with the crank pulley you might have to turn the cam pulley a bit. This is okay to do.
