toad101 just can't get enough Parked in the garage Written a guide Joined Apr 21, 2006 Messages 5,077 Points 887 Location south east wales Aug 2, 2006 #1 cinq sporting bad vibration nsf when pulling off wheel moves side to side if pulled hard
R randomizered ' Parked in the garage Written a guide Joined Feb 16, 2005 Messages 5,983 Points 988 Aug 2, 2006 #2 Bearings, loose bolts or bushes most likely. Model car?Standard wheels?Age? Kristian
OP OP toad101 just can't get enough Parked in the garage Written a guide Joined Apr 21, 2006 Messages 5,077 Points 887 Location south east wales Aug 9, 2006 #3 sorry been a while wifes car don't get 2 use it much, just had a look at it nsf shock leaking, vibration could be lack of traction , a lot of vibration when turning left
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Aug 9, 2006 #4 I can't see it being the shock (although it could concievably be loose bolts on the shock). As kritip, but could be CV joint or even the NS gearbox mount breaking up.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Aug 10, 2006 #5 I start with the gearbag mounting. Cheers D
OP OP toad101 just can't get enough Parked in the garage Written a guide Joined Apr 21, 2006 Messages 5,077 Points 887 Location south east wales Aug 28, 2006 #6 changed shock still got vibration, mount under gearbox damaged
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Aug 28, 2006 #7 toad101 said: changed shock still got vibration, mount under gearbox damaged Click to expand... Yup, that will be the one. Cheers D
OP OP toad101 just can't get enough Parked in the garage Written a guide Joined Apr 21, 2006 Messages 5,077 Points 887 Location south east wales Sep 22, 2006 #8 fixed at last, cheers
