would they fit a mk1 punto?
charlieboy said:would they fit a mk1 punto?
will do. haynes manual?Liam said:Also you may want to obtain the correct torque figures and some threadlocker when fitting new belts to ensure maximum safety.
Liam
Liam said:The pretensioner is usually on the latch part of the seat IIRC it's that which pulls the belt tight on impact, it's got nowt to do with the reel or belt itself, you should compare the metal part which couples to compare them cos the Punto might be different.
Liam
