The plastic/rubber side strips are held in place using tigerseal, which is an absolute bitch to get off without scratching or damaging the paint underneath. You can with care get them off with a pallette/craft knife, but it will take time and losts of patience.
The holes are only 5mm in diameter and can be filled and smoothed with ease.
However if you have not got the rubber/plastic strips and it's just the vinyl transfers then you just need a hair dryer and carefully heat the sticker and pull off in a steady but constant speed.
