General bodywork on chinq
simi
rotherham
Hi people i started doing some bodywork on my car here are some pictures of what i done so far i want to mod the back bumper anyone have any ideas :slayer:
needs lot more work also removed the wiper and water jet aswell all smoothed off now will post updated pics soon
bonnet needed alot of work to it when i got the car as you can see its a different colour again all smooth after hours of trying
started to primer the bonnet ran out of paint :(
cant tell where the badge was
this was my first atempt using filler and im pleased with the result its not that hard to use it just takes time and effet to get the finish:)
DID YOU TAKE ALL THE PAINT OFF BEFORE YOU STARTED AS IF YOU DIDN'T THE THE FILLER WILL JUST POP OUT OVER TIME OOOOHHHHH (n)
That doesn't look quite right. As someone else has pointed out it's bad practice to filler over paint. Also you have very defined edges to the filler, it needs to be feathered out at the edges.
Once you put some primer on get a rattle can of dark paint and guide coat it. Literally a very light mist coat of paint. It'll look like its been spattered with paint. Then get a block and some 600 grade wet and dry and lightly dry sand it. That will show you any islands you have, the guide coat will reman in the low spots. Remember paint is about preparation, it will NOT hide any imperfections, it just provides the colour.
Pete
you've got the right idea mate.. but if you didnt take it back to bare metal get it out and do it again. word from the wise fillerworks allot harder than painting. be real. (y)
Gaz
dam i thought i only needed to take the shine off the paint so i need to do it all over agan :( i had it right smootaswell:mad: :mad: :mad:
when i filled my bonnet i went right back to bear metal and i also hit the two holes in the bonnet in, so they was not flush with the bonnet if you know wot i mean hope this helps:) :)
Glad someone mentioned this. If you havnt already done this, yor filler is too weak and when you finally get it looking nice, the filler will crack and fall out takign your paint with it = wasted effort. Get the filler out, and smack the holes in a little to give the filler some more surface area. Only sand with a block and continue until you cannot feel any change in texture after using 500 grit. 2k primer, flat back and top cot and laquer follow. You will get a poor finish if you spray it yourself - hope that helps but seriously, start again.
Jordan
use glass bridger for the bonnet first then use filler to get it smooth the stuff goes well hard and it will not crack out. like above you will have to use a hammer to dent the panel so there is a lot of surface area
