im Axle Specialists
Old 28-06-2006   #1
Advanced Driver has donated!
Help - Replacing Window Seal
Right, I'm half way through this job, but can't work out how to do it. I've removed the wing mirror, removed the arm rest, freed the fabric, and freed the white paper stuff. How do I remove the fabric completely? It's stuck at the top.
I can't remove the door handle completly either the rod is in there, but I can't take the rod off. It looks like the things should just squeeze together and push through, but they won't go through, and the plastic bits are getting very damaged now.
Workshop manuals aren't much good really because nothing shows how to do this on a Sei.
Do I also need to replace the inner door seal thing as well, or can the outer be replaced on its own?
I have a Seicento SX (1999) btw. Hopefully I will be able to fix this today.
Advanced Driver is offline Reply With Quote Quote
Old 28-06-2006   #2
Question Re: Help - Replacing Window Seal
I've got the replacement part now, and have been trying to figure out how it goes in. I've come to the conclusion that it must go in from the outside because the exterior trim is longer than the window. I still can't work out how the old one comes out though, or how why it needs replacing and cannot be removed in one piece.
The plastic is a funny 'S' shaped kinda thing with a curly bit at the end. I still can't remove the interior trim ('door card'?) either, and I'm worried about breaking the inner plastic/seal thing.
Old 28-06-2006   #3
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
The doorcard definately has to come off thats all i can tell you
i had this done when mine came off, by a mechanic and said it was an absolute fiddly job to do
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
Old 28-06-2006   #4
I had to give up
My dad pushed the old one in with a screw driver, and it seems to be OK now. I wonder how long it will last though
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
(T) Window Seal!!!!! Jetsfan5 Cinquecento / Seicento 2 05-04-2006 10:04
(T) window seal cinqy_smurf Cinquecento / Seicento 13 02-11-2005 15:02
(T) Replacing sunroof seal TidyBoy Bravo / Brava 9 27-10-2004 16:58
URGENT - window seal MikeWhitcombe Lets Talk FIAT 6 09-08-2003 17:10
