Hi everybody!
I bought a tachometer for 4/6/8 cylinder engines and I'd like to mount it in my Seicento 900SPI SX. Now I read here the Sei has a weird ignition system and you need to use a 2-cylinder tachometer. The guide coming with the meter says you need to connect the green wire (tacho signal in) to the coil negative (-) or electronic ignition. Is there a way to connect it to both coils, or do they have a shared negative wire or something? Or is it possible to connect it somewhere where both signals come from?
Hope somebody can help me
Tim
Tim
