Technical Engine Problems Fast response needed
Tweedbean
Va Va Vroom
Birmingham
Hi selling my car when suddenly it starts to overheat constantly. What it does is after i drive it for a couple of miles, it throws the contents of the water coolant tank out the bottom of the car?
Just had a new radiator and fan switch but it is still doing it, any ideas?
James B
Sounds like what happened to my sei . It ended up being the water pump leaking !!!
had the radiator done yesterday because it had a leak. had the problem last friday so took it in and they changed this and checked the head gasket. water is coming from under the cap on the tank which they also replaced the cap so it not that either
Check near the thermostat. The water in the engine just goes round the engine until it gets hot, then the thermostat opens and passes through the radiator, so if it does it after a while then it sounds like its after that.
