General rear drum brakes with pics question
Coventry (near Birmingham
right been doing the left rear drum brake today as it was stuck. now ive got the cover off (broke a clip in the process)
looked at the apd things and they look in good nick to me, everything does, apart from one thing
pics of rear drum brakes (look really clean to me, from other threads ive read) and the pad things look new, what do you lot think?
[/IMG]
and now the thing im confused about, the pad thing dont sit all the way in where the piston groove is, yet the other side does :confused: is this right?
[/IMG]
Check for leaks around the cylinders and free up the handbrake levers and adjust the cable accordingly and you should get a decent brake for the MOT.
Liam
right ive had a play but the drum still wont move, i think its down to the friction pads. the handbrake is off, not that it works any way. the other part of the drum will spin freely with out the drum on but when the drum is put on the friction plates stop the drum turning.
what have i got to do next?
custard boy said:
why one side?if you push both sides you can centre them rather than having them to one side:rolleyes:
tried to get the friction plate in so i only pushed one side. tryied both side now an neither will move. should both the things that the friction plates slot in to both move inwards?
any way had a little play and i can get it to spin freely with out the hub on again. put the hub on and it still moves fairly freely start putting the two little bolts on and it slows down, start tightening the nut and it back to square one :( very little movement
so this must rule out the springs as it moves freely around them when not tightened, so my thoughs are its catching on some thing. rubed down both the hub and the backing plate to get rid of rust, still the same :bang:
Late into this one, and i'm a wee bit lost about the different hubs that you seem to have.
Firstly, mount up the hub, the bit with the bearing in it. That should spin freely. Leave it on.
Make sure the drums have no lip on the inner edge, if so, grind it away.
Try and fit the drum over the shoes. It should go on with a small amount of drag.
If it does not go on, use two large levers, one either side, to skweez the shoes together to allow the drum to just fit. The shoes need to be centred, also using the levers.
Hope this helps
D
sounds like the drum is rubbing on the edge of the shoes
looking at that picture it looks like youve lost one of the clips that holds the shoes in place.
just check the shoes are sat back in place properly
